IC-402 doesn't work
  • Albonline
    • Sep 2008
    • 1147
    #31
    You can preload a hdd for most fiery controlers. i do it all the time . you need a program called drive copy and a known good system drive for the controler in question. if you use a drive that is too large scan to email will not work . the standard drive in an ic401 is 20 gig. also once a non efi drive is installed you will NEVER be able to parrallel load that unit again!
