KM C220 Faded to blank output
  • bayshoreoe
    • Jun 2015
    • 44
    [CQ] KM C220 Faded to blank output
    Customer has this unit and complaining of light going to blank prints. Printed a report from machine and it was blank. Made color copy to see if all were blank or only black. copy came out fine. printed report again, fine. Customer called a few hours later, blank output. swapped black and cyan drums to rule out drum. After a few(50) or so prints, got light and went blank. DV brush is good.
    Any ideas? Not that familiar with KM color.
    Brian
  • acusso1234
    Tecnico
    • Dec 2008
    • 250
    Re: KM C220 Faded to blank output
    Hi. Try changing the K developing clutch.
    Service manual explains how to do this.
    Your black developing unit is not rotating due to that clutch that probably is slipping.
    ... In the minute that you're thinking of giving up, think about why you lasted so long ...
    • neil greenhough
      • 51
      Brian
      Yes accusso is right. The dev clutch is slipping. Changed one today, one of many!!
      • bayshoreoe
        • Jun 2015
        • 44
        Would anyone happen to have the part number for the BK DV clutch?
        • JR2ALTA
          • Feb 2010
          • 2030
          Weird, I've never had to change a DV clutch
          • allan
            RTFM!!
            • 5462
            I have had the drum clutch fail. need to change the entire drive.
            Whatever
            • acusso1234
              Tecnico
              • Dec 2008
              • 250
              A0EDM20000 CLUTCH
              • bayshoreoe
                • Jun 2015
                • 44
                Thank you all so much for the assistance
                • hotfuser
                  • 180
                  the wire cracks at the joint of the clutch.
                  KM put a bulletin up after we advised them of what the issue was.
                  They also released the clutch as a seperate part due to the fact it didnt come as a single part only as a complete drive.
