C-452 magenta problem
  • chivozx
    • May 2014
    • 34
    [CQ] C-452 magenta problem
    Hello, the imaging unit magenta toner developer and spits the bottom of the unit.
    I tried it with another developer station and follows the failure.
    The drum is new, the charging unit cleaned it and have tried with another.
    I changed the density values and charge from the technical mode without any result.
    I'm desperate, I hope your advice.
    Greetings.
    Hola, la unidad de imagen magenta escupe revelador y toner por el fondo de la unidad.
    He probado con otra estacion de revelado y sigue el fallo.
    El tambor es nuevo, la carga la limpio y he probado con otra.
    He cambiado los valores de densidad y cargas desde el modo tecnico sin ningun resultado.
    Estoy desesperado, espero vuestros consejos.
    Saludos.
  • allan
    RTFM!!
    • 5462
    Re: C-452 magenta problem
    Did you rebuild the imaging unit?
    Whatever
    • chivozx
      • May 2014
      • 34
      Yes, but with another original development unit it do the same. A tot of develop and toner spits
      • allan
        RTFM!!
        • 5462
        Is that on the front of the unit?
        Whatever
        • chivozx
          • May 2014
          • 34
          No, the problem is on the bottom of unit
          • allan
            RTFM!!
            • 5462
            change the Imaging unit with a new one. There is a seal that breaks on the waste port that would drop toner on the front side of the unit when you rebuild it.
            Whatever
            • chivozx
              • May 2014
              • 34
              Is this piece you mention?
              • allan
                RTFM!!
                • 5462
                Looks like it.
                I don't rebuilding these units. They are toast at the end of the 3de cycle and will damage the drive if over run. Replacing it will fix your problem. Are u sure its not the drum??
                Whatever
                • chivozx
                  • May 2014
                  • 34
                  The drum is new, no wear. It may come wrong, but all the developer falls into the gears
