Konica Minolta. Bizhub C452 network printer offline problem
  • parsmehregan
    • Jun 2012
    • 97
    Hi,
    In on of client's local network there are two Konica MFP, Bizhub C452 & Bizhub C552. Both of them were installed correctly on the main system with Windows 7-64bit operating system.copy ,print and scan worked fine.but after a while on of the MFP machines,C452 had some issues with printing, and doesn't print documents and if restarting the system it runs the previous print command if it hasn't been canceled before restarting.
    and finally doesn't print at all after a while!
    in print management , queue status shows offline the printer.other functions works well and I did replacing driver ,IP ,turn machine on and off ...
    didn't solve the problem.
    The interesting matter is that the other machine(Bizhub C552) works well,so from the web setting I compared all setting for both machine and make both equal (they were almost the same).
    I tried to install the Bizhub C452 on one of network system directly ended with same problem : it installed correctly but shows offline ,so i suppose it may not be operating system issue.
    So if you have any experience with similar issues or know the solution ,that would be great if share it with us.
  • mo0651
    • 1054
    Re: Konica Minolta. Bizhub C452 network printer offline problem
    Have you isolated the machine with a laptop and crossover, or a switch? to see if it is machine. may be a port on their switch? Have you pinged the machine for any IP conflicts?
    • copyrooks
      • Oct 2013
      • 209
      Check service mode for error codes that might have reset the copier.
      • parsmehregan
        • Jun 2012
        • 97
        I didn't check the machine with crossover cable ,but I pinged machine and server separately with no conflicts.I'll check connection with crossover cable .
        Also I've ran into some solutions about SNMP settings.It suggested to disable this function and see if it works!
        • Mr Spock
          Vulcan Inventor of Death
          • Aug 2006
          • 2064
          Turn off snmp and set the network card to 100 full duplex not auto negotiate and see if that works.
          • parsmehregan
            • Jun 2012
            • 97
            I asked the client if he accidentally reset the machine in administrator mode,...negative.
            but I'll check the error codes.
            thanks
            • Albonline
              • Sep 2008
              • 1144
              What he said!
              • emujo
                • Jun 2009
                • 3009
                This issue is almost always related to SNMP..I would not turn the feature off, but look more into the customer's network to see if the default SNMP read/write values are anything but pubic/private. You may also want to go into PSCW and verify the defaults have not been changed here. The MFP and the network must match in order fro the driver to communicate properly and pull the config. I'm not sure about the C452, as this is a little older, but I would look at the 2 MFPs and check the function version level. If they are different, then you will need to use the proper drivers. We see this a lot in the e series MFPs..MFP at version 3, and drivers at ver 5.x. Configuration never pulls. This is a problem especially when authenticating. When all else fails, jot everything down and perform a network initialization. Sometimes the slightest bit of corrupt port settings/SSL certs, etc don't really manifest at the copier level, but can add up when utilizing the network functions. Emujo
                • peter42
                  • Jan 2012
                  • 110
                  have really notebook with crossover cable connect to machine.
                  i had so many trouble with old networks and the 1000/100/10 automatic in KM-machines.
                  print works, scan fails, otherwise PS-Print fails, PCL was fine.
                  Sometimes a desktop-switch helps, sometimes not, its mostly old CAT5 cabling not Gbit certified.
                  Its not a joke, try first the small way between system and customers PC.
                  A 5 port switch and two patch-lines out of your help-box.
                  If that works than you are out of any trouble search, your job is done, instead you are also the IT-Distri. ;-)
                  • EarthKmTech
                    Step aside, noob
                    • May 2009
                    • 2139
                    We had a site full of C652's dropping off the network and tried absolutely everything, what you say is correct about putting a small switch in between the machine and the network - it solved it there too.
                    • parsmehregan
                      • Jun 2012
                      • 97
