bizhub 3320
  • Imsdal
    • Aug 2009
    • 111
    bizhub 3320
  • Synthohol
    Certified Konica Expert
    • 5829
    Re: bizhub 3320
    thats probably SMTP setup for scan to email.
    if you log into the copier's web page as admin, you can turn SMTP off under email settings.
    • Imsdal
      • Aug 2009
      • 111
        • 14737
        Re: bizhub 3320
        Did you use the solution you were given by Synthohol?
        • Choclit007
          • Oct 2010
          • 58
          Re: bizhub 3320
          Put any IP address into the SMTP field and the message goes away
          ie 1.1.1.1
