power on external vending device Bizhub c308
  • Sharptech56
    • Feb 2016
    • 100
    [Electrical] power on external vending device Bizhub c308
    I have a new install at a Library . I had this Jamex 6557 installed on a Sharp MX-2615N and it worked fine.
    Installed a Bizhub C308 and every other day it says" power on external vending device". The customer
    has to unplug the coin box and replug it . I have tried firmware turned off power save and added
    surge protection called both Jamex and Konica Minolta but no luck . Any ideas what to try next ?
  • Iowatech
    Not a service manager
    • 3930
    Re: power on external vending device Bizhub c308
    Check for loose connections in the coin box, especially with the cable that interfaces with the MFP. There's a chance that something inside it got knocked out of place during the MFD swap.
    It probably would be a good idea to check that the signal from the coin box is what that MFD expects. New machines from different manufacturers sometimes have different requirements.
    Beyond that, I'm not sure. I used to have decent experience with external controllers, but that was with ACDI stuff.
    • Sharptech56
      • Feb 2016
      • 100
      Thanks I will check those things next visit.
      • oldschool
        • Mar 2007
        • 245
        I would suggest disabling sleep mode rather than power save. The other steps are checking the wire harness and board. I suspect you've already changed both. If you have contacted Konica Minolta and have a ticket number I can email the contacts I have at Konica Minolta to see if this a known issue with this model. contact us at supportatjamexvending.com. This seems like something for Konica Minolta engineering. We can visit a local dealer to get more information but I suspect the copier is going to sleep and stopping communication with the Jamex. Once that happens the copier doesn't seem to reinitialize communication unless one or both of the devices are power cycled.
        Jamex Tech Support: Saving the world one phone call at a time.
        • Sharptech56
          • Feb 2016
          • 100
          I will get more details and update the thread
          • antone
            • Oct 2014
            • 344
            I have a ACDI.. coin op and on the .Control Panel ...it does not say insert funds! But if put money in the coin op and make copies..it uses up the money. But no message insert funds
            Sent from my SM-N950U using Tapatalk
            • Synthohol
              Certified Konica Expert
              • 5805
              try a different vendor mode in tech rep?
              older machines did the same thing, the button stays orange and only turns blue when money is input.
              • antone
                • Oct 2014
                • 344
                Replaced MFP sovled problem!
                • Synthohol
                  • 5805
                  thanks for the update. its nice to close a case
