strange color misalignement Bizhub C452
  • rindraintsoa
    • Sep 2010
    • 55
    [Misc] strange color misalignement Bizhub C452
    Dear all,
    I am facing a strange problem, when I print green color I found misalignement (as in the sample picture) mainly in yellow color. I can't use the color registration because the misalignement is not in the whole area of my pitcure but only in some areas.
    There is no P codes, I have tried to change the Yellow Imaging Unit and also the transfert belt and the PH unit but the problem still persist. I have also tried to change the fusing unit but no good result.
    Can anyone suggest me something to do? thank you very much for all.
  • imihm
    • Feb 2014
    • 77
    Re: strange color misalignement Bizhub C452
    Originally posted by rindraintsoa
    Dear all,
    [ATTACH=CONFIG]32281[/ATTACH]
    HI there....
    Check the FCC to the laser driver pwb pin or pins not deformed...
    Thanks...
    • mo0651
      • 1054
      Clean the fuser entrance sensor(loop sensor).
      • copier tech
        • 8237
        Have you performed initialisation+stabilisation ?
        • rajabi1367
          • Dec 2015
          • 5
          I've had the same problem, even tried changing IU with another machine and ... No improvements but the problem got solved after one day when I turned on the machine!
          • korthr5
            • Feb 2016
            • 39
            Hello
            if you dont clean the IR sensors down of the transfer belt, changing the image unit or the TB dont solve the problem
            • JM1
              • May 2019
              • 2
              That's where the problem is the (loop sensor) maybe it shift a bit r out of line cause i had that same problem n technician keep telling me all sort of stuff but realize that it is the same (loop sensor) that's causing the problem
                thanks for robbing a 4 year old dead thread.
