biz 259 c2557
  • Gab
    • Aug 2015
    • 668
    biz 259 c2557
    Tis code appeared after customer tried to use toner for bizhub 210 . When i used the corect toner it looks like when it tries to rotate it a sound like it can't rotate it and error 2557 appears. Error does,t appear from the beggingn when i turn on machine.
    I ask can it be some problem with toner drive mechanism or somethig .
    • 14526
    Re: biz 259 c2557
    Replace dev, vacuum out toner hopper, install proper toner. That should do it.
    • Gab
      • Aug 2015
      • 668
      Re: biz 259 c2557
      Sorry i mean biz 250
      • Gab
        • Aug 2015
        • 668
        Re: biz 259 c2557
        I think no new toner added from the wrong bottle. Are you sure it's the toner ? Can it be the toner drive mecahanism?
        • DigiMan
          • Jan 2013
          • 262
          Re: biz 259 c2557
          You can open the toner door and use your hand to see if it tries to rotate before
          popping the code.
          I don't like the new copier I just bought. It says "put face down" but every time I do it, it blinds my eyes.
          • allan
            RTFM!!
            • 5462
            Re: biz 259 c2557
            I will break a spot welded shaft from the bracket on the toner drive train if it gets enough strain.
            Many moons ago KM did make the replacement part available.
            Whatever
