Bizhub C353 Scanner can not be used
  • copyalbania
    • Aug 2009
    • 165
    Dear friends i have a problem with a konica minolta bizhub C353, in the display is the following message " The following option can not be used because the scanner is not avaiable copy, scan, fax.
    Also has a question mark in the end of the display and says Tray 1, 2 LCF can not be used currently...
    The machine previously had the error C-EE2
    Please any one can help?
  • allan
    RTFM!!
    • 5462
    Re: Bizhub C353 Scanner can not be used
    If some problem reoccurs the machine would latch the unit for service and safety reasons.
    You should goto service mode -> system 1 -> problem unit isolation and unset the scanner.
    But first look in the counter history for the error code that caused the problem. It would probably just happen again.
    for the ??? you get next to the paper icon, it means the paper size detection does not work correctly or there could be paper stuck behind the tray.
    Remove the trays and inspect for damage. Some of the problems does not appear obvious so the inspect it properly.
    Sensor check mode under service mode -> state confirmation is very helpful in finding problems.
    Whatever
    • copyalbania
      • Aug 2009
      • 165
      Thanks Alan,
      I will try it but in the history error code there is nothing everything is deleted maybe by some other technichen i do not know.
      I will try and let you know.
      • copyalbania
        • Aug 2009
        • 165
        Hello Allan,
        I did what you suggested me and now the message is not appearing and the scanner moves ok.
        I try to copy but it scan the image ok and even though it has paper the machine says replenish paper ...it detects paper size and also also lights the light that has paper ...just the bypass tray is ok.
        i do not understand any help if possible?
        • allan
          RTFM!!
          • 5462
          Make sure the paper it detects of off the glass is the same as the paper loaded.
          First select the paper tray and then copy, does that work?
          Whatever
          • copyalbania
            • Aug 2009
            • 165
            Hello Allan.
            Yes i have trying to select paper tray first and than hit start and the same thing happened it paper load....i do not understund
            • allan
              RTFM!!
              • 5462
              Make sure the paper lift motor coupler is not broken or that the plastic arm that lowers the pickup roller is not broken.
              Could also be a sensor problem.
              Whatever
              • copyman
                Owner / Technician
                • Sep 2005
                • 4718
                Look for piece of paper stuck behind paper drawer. You may have to look behind with flashlight or remove drawer (1 screw and small metal plate.)
                Could be paper sensor actuator arm is broken.
