DIRTY BACKGROUND ON C552
  • cayyell
    • Feb 2013
    • 82
    Hi,
    I have a C552 with a light colour lining, inline to the paper path on a print out. but it only on colour print, but black print is ok.
    on testing for lattice pattern, while setting both width to zero, i get a perfect white print on Black (1PC), while selected Yellow only, all the CMY have the faint lining.
    things i have done, swap all the colour IU and Transfer unit, same result.
    so now should I change both the HV board? or is there anything else?
    while i was trying a scan the faulty print, it was too faint to be visible by the scanner.
  • konica7022
    • Nov 2008
    • 132
    Re: DIRTY BACKGROUND ON C552
    Originally posted by cayyell
    Hi,
    have you tried cleaning the image transfer belt unit?
    • cayyell
      • Feb 2013
      • 82
      Yup, already done so. Even swap from a working spare units
      • copier tech
        • 8132
        Can you post a sample print?
        โ€‹
        • cayyell
          • Feb 2013
          • 82
          i tried my best to scan it.
          the actual print have yellow and magenta lining, but the scan only show cyan lining on the top
          SKMBT_C35216032815430.pdf
          darkbackground removal.pdf
          second attached a darker background removal, but you can see the lining more visible but please ignore the dark grey background
          • marvin_PL
            • Jun 2012
            • 24
            Did you solve problem i've got exactly same in c220
