konica 750 not printing when pressing start
  • W242
    • Aug 2009
    • 43
    Konica/bizhub 750 I put an original on the glass or doc feeder and press start and it will say printing, but nothing is happening. I can turn of the main switch for about 5 minutes then turn on and it will usually work again for awhile but goes back to same issue.
    Any ideas what is causing this problem?
    • 14932
    Re: konica 750 not printing when pressing start
    Clean the two sensors under the drum. This is a symptom of a dirty TCSB
    • LASSSEN
      • Feb 2016
      • 13
      Hi!
      first we need more information about your engine as consumable life espicialy the drum and developer
      what message is in the lcd
      • W242
        • Aug 2009
        • 43
        I cleaned the sensors and it seems to be working good now.
        I never would have guessed that they could be related to the problem.
        Thank you!
          • 14932
          Thank you!
          Thanks for letting us know that you got it fixed.
