How to reset fuser error on Konica Bizhub C253
  • syam201
    • Jul 2015
    • 10
    Dear Friends Pls let me know how can we reset the fuser error on Konica Bizhub C253
  • habik
    • 2013
    Re: How to reset fuser error on Konica Bizhub C253
    What code do you get? That narrows the fault finding to usually specific part.
    Take fuser out and measure resistance on the lamp, thermistor, thermal protection. If all looks OK, then try trouble reset (look on other threads, you'll find procedure how to), if that doesn't work, then check the voltages on power supply. Other than that, you better of with new machine then replacing boards.
    Firmwares HERE
    • Synthohol
      Certified Konica Expert
      • 5839
      system 1, initialization, system error clear, roboot.
      if the code comes back replace the fuser
      • Callboy6
        Hello,
        1. Turn OFF the main power switch.
        2. Turn main power switch ON while pressing the Utility/Counter key.
        3. Touch [Trouble Reset].
        4. Check to make sure that [OK] is displayed and the it has been reset.
        5. After turning off the main power switch, turn it on again more than 10 seconds after and check if the machine starts correctly.
