C 6501 unknown problem
  • selmila
    • Aug 2012
    • 133
    [Error Code] C 6501 unknown problem
    Hi all.
    I have a strange problem with C 6501 in which C 5001 code shows up when the toner supply unit is closed.i have changed the defect component ICP 22 and ICP 15 on the prcb but still the component blows off. Any suggestions to rectification is appreciated.
    • 14997
    Re: C 6501 unknown problem
    Originally posted by selmila
    Hi all.
    I am not an expert on this machine, but, when you are getting blown ICPs consistently, maybe you should be looking for either a short to ground or maybe a fault in the toner drive. Just constantly replacing the ICPs isn't really fixing the problem. Look a little closer.
    • Synthohol
      Certified Konica Expert
      • Mar 2016
      • 5901
      Workaround/Fix
      CAUSE: Failed Printer Control board or DCPS/1.
      SOLUTION: Check ICP22 on the Printer Control board to see if it is OPEN. If it is OPEN replace the Printer Control board (p/n A03U R7B5 00). If the ICP fails again, check the 12V DC supply to PWB-CVDB, the TCR sensors and the gamma sensor because PWB-PRCB supplies 12V DC to each of these components. If ICP22 is not OPEN and there is no 12V DC, check DCPS/1 (p/n A03U M401 00). It supplies the 12 volts to the Printer Control board.
      • selmila
        • Aug 2012
        • 133
        Originally posted by Synthohol
        Workaround/Fix
        i have replaced PRCB but still the ICP 22 fails again.i have also changed DCPS/1.
        • Synthohol
          • Mar 2016
          • 5901
          check your DV units or exchange them, ICP 15 is the TCR sensor if its the same as a 6500. could be a short?
          icp 22 is a 12V DC abnormality, thats the stumper, could be anything.
          • selmila
            • Aug 2012
            • 133
            ok i will check with the DV units today, thanq
            • selmila
              • Aug 2012
              • 133
              replaced all DV units but now the machine gives a new Error C 6101.checked all connectors and wire,all good even cross checked PRCB.
              • Synthohol
                • Mar 2016
                • 5901
                At the home position search,
                scanner HP sensor (PS1) is not
                turned ON within the specified
                time after the scanner motor
                (M1) is turned ON.
                check the home pos sensor and or reseat all your board connections.
                • selmila
                  • Aug 2012
                  • 133
                  (M1) is turned ON.
                  hi i checked with all the boards and conectors thay all looke good and in that proses the errors has got rectefied but stuck at C 2721 while printing,rechecked all boards and also replaced HV/2. any sugustions.
                  thanks.
                  • Synthohol
                    • Mar 2016
                    • 5901
                    An error detection signal of
                    the separation charger is
                    detected while the
                    separation charger is ON.
                    The signal is detected
                    even after turning OFF/ON
                    for a prescribed time.
                    Check the sep assy in front of the xfer roller. Maybe wire is loose or there is a wire on the HV board off or not good contact?
                    • selmila
                      • Aug 2012
                      • 133
                      detected while the
                      hi
                      have checked all connectors and wires and also changed the transfer roler unit.
                      • Synthohol
                        • Mar 2016
                        • 5901
                        Is the electrode making good contact on the roller?
                        Also ive seen the wire pinched frayed or loose on the sep plate.
