konica 7050 bypass tray not functioning on platen memory
  • mdm7266
    • Dec 2007
    • 99
    hello there! is there a program so that i can use bypass tray when using platen memory?
    i can use only platen memory on trays. when i select platen memory and scan originals, then i select bypass tray, the copier says : platen memory cannot be use on bypass tray .
    i want to use platen memory using bypass tray. Is there a program to input so that i can use it?
    mdm7266
