Copies Have Squares - Bizhub C550
  • bungapads
    • May 2009
    • 69
    Does someone know why, when I make a copy the copy itself comes out with small 3/8" x 3/8" squares over the copied document. What is the fix?
  • Synthohol
    Certified Konica Expert
    • 5806
    Re: Copies Have Squares - Bizhub C550
    it was not setup properly following the install instructions.
    you can try just doing gradations but i would follow the install sheet in order.
    • bungapads
      • May 2009
      • 69
      Thank you for your response. What install sheet are you referring to?
      • Don N.
        • Nov 2011
        • 409
        From experience with c253/c353 series, I did just the gradations (3 each of all types) several times & still had the squares. This was after we had to do an NVRAM clear, & setup is needed.
        I failed to continue with the next few steps including setting the machine serial no. (even though it was already set, go in & act like you entered it) and set the time in the service mode, etc. Just follow the setup exactly and the squares will go away.
        • bungapads
          • May 2009
          • 69
          Thanks. I just did an NVRAM set up on the C550 recently. I do not have the install- setup instructions. Could you send them to me?
          Lastly, I have set up the Fiery ic-1409 in the past and currently. My computer can browse to the Fiery but it is as though the copier is not seeing the fiery. I try to input the password for the fiery which is Fiery.1 by default and the controller says incorrect. I input the admin password and it says the same thing. Any clue what is going on?
          • hotfuser
            • 180
            it sounds like you havent set the controller type in 'system2' in service mode to 'controller type 1'
            • Synthohol
              • 5806
              here, i couldnt find 550 but the 450 is the same.
              bizhubC450InstallGuideVer03.pdf
              • bungapads
                • May 2009
                • 69
                Thank you for your comment. I did go back and reset it but I still cannot print. It is strange because I cannot think of anything else that would prevent the C550 from printing. I am not able to log into the Fiery using the Fiery.1 password which is also strange, even though I can browse to the fiery using control panel on C550 or computer IP address. If I could get around this fiery password issue, I could run set up and that would probably fix things. I also tried three different ways to set IP address for c550 with a Fiery, auto, manual (one number greater than ip for fiery) and another ip greater than ip address for fiery. None worked. Any clue?
                • Synthohol
                  • 5806
                  On the copier it should be set to auto dhcp. (Crossover cable from fiery to copiers rj45
                  Having the fiery assign the next IP up is an option in network setup on the fiery.
                  Have you tried a blank password?
                  If you get desperate enough let me know and ill link you to system software on my home server.
                  If you do go that route, install poweriso on your laptop. You can mount .iso images as virtual dvd drives so no need to burn disks anymore.
                  Doing it that way for years flawlessly.
                  • bungapads
                    • May 2009
                    • 69
                    Thanks for the help. I was able to go through the set up on the C550 and now I can print to it without squares.
                    The last issue is that I do not know the password for the fiery and I am not able to use command workstation except as guest. I need to log in as administrator to control color, etc. Tyring to figure out what the password is.
                    • ZOOTECH
                      Senior member of CRS
                      • 3375
                      By default, the password is Fiery.1: if it has been changed, there is a post script file that will print out the new password.
                      • Synthohol
                        • 5806
                        yeah, we are working on this in another thread
                        • ZOOTECH
                          • 3375
                          Well excuse me for duplicating a previous post.
                          • Synthohol
                            • 5806
                            hehe, i didn't mean it like THAT
                            • ZOOTECH
                              • 3375
                              No problem Steve. I think I was channeling a Steve Martin thing.!
