C550 Bizhub and Fiery Controller 1409
  • bungapads
    • May 2009
    • 69
    This Bizhub C550 has an upgraded Fiery installed (not bustled fiery). I think the model in 1409. I have set all the IP information for the fiery. I was able to browse to it, but now I cannot. I went to the control panel of the C550 to verify the IP address of the Copier and it is set to one number higher in IP address than the fiery...which is what the instructions say. However, when I go to controller details in the panel and try to run set up, I cannot because it is asking for a password. Everything I put in is incorrect. I put in Fiery.1 - no luck, I put in the machine's admin password - no luck. Does any one know what password might work. I also tried 1234567 - no luck.
    Also, I cannot access the fiery through the admin panel on the Command Workstation because it wants the admin password. None worked. This all worked in the past, so I cannot figure out what happened.
  • RRodgers
    • Jun 2009
    • 1947
    Re: C550 Bizhub and Fiery Controller 1409
    Search for the Fiery password grabber file. Send this file to the Fiery and it will just print out the password. I forgot what it's called. I have it laying around someplace...
    • DigiMan
      • Jan 2013
      • 262
      Longshot but...SysAdm???
      I don't like the new copier I just bought. It says "put face down" but every time I do it, it blinds my eyes.
      • peter42
        • Jan 2012
        • 110
        Have a look at this
        http://www.copytechnet.com/forums/co...html#post57819
        greetings peter
        • CopyJunkie
          • Oct 2012
          • 28
          password.ps hasn't worked for me on any recent fiery's, it just prints out of bunch of garbage text... but I still have it if you want to try. I think you're looking at system software to reset the password, at least you should be able to get a config page out of it right?
          NOTES ON HOW TO USE THE FAX MACHINE.
          1. Get into your DeLorean (or your TARDIS) and go back to 1990.
          2. Place papers in the machine - Face Down.
          3. DO NOT dial 9
          4.
          Rejoin the rest of modern civilization.
          • bungapads
            • May 2009
            • 69
            Peter. Thanks for the file. Unfortunately, I am not able to print to the printer. I am able to browse via the ip address to the fiery. I am able to browse to the fiery through the main screen of the C550, but not able to run set up because I do not know what the password is. It looks like I will have to re-install the fiery software. Do you have instructions on how to do this?
            • RRodgers
              • Jun 2009
              • 1947
              you don't print the file you import it via the web app or command workstation
              • bungapads
                • May 2009
                • 69
                Thanks for your reply. If you have some instructions on how to print that file, please let me know. I was unable to unzip it, but not sure how to actually print it to the fiery to get the password. As to the last statement I am not sure what you are referring to. Could you be more specific about the config page. I was able to print a configuration page, but I do not see the password listed there. Is this what you were talking about? Is the password there?
                • bungapads
                  • May 2009
                  • 69
                  I must be missing something. I went to the link you provided. I unzipped the file. I then went to command workstation and imported it. The only option I get in the import window is to HOLD. What do I do now?
                  • RRodgers
                    • Jun 2009
                    • 1947
                    you "might be able to import it into the hold que and release from there.
                    • Synthohol
                      Certified Konica Expert
                      • 5822
                      IIRC you can also setup a lpr printer queue set to Direct and drag the password file into the printer icon created.
                      If the page that prints onlly reads Password= " " the admin password is blank.
                      • CopyJunkie
                        • Oct 2012
                        • 28
                        Like RRodgers said you should be able to print it from the hold queue or you could just "Process and Hold" and preview it with CWS5. The Password is not on the config page. I was just saying if you redo system software it'll much easier to put the information back if you have it on paper.
                        3. DO NOT dial 9
                        4.
                        • bungapads
                          • May 2009
                          • 69
                          I do not know how to set up an LPR printer on windows 10 and I cannot find an article on it. DO you know how? Is there any other way to print this ps file and see the password
                          • RRodgers
                            • Jun 2009
                            • 1947
                            AGAIN put it in the queue and then move it from there, it will print out the password. Make sure it comes out on portrait paper or you wont see it as it comes out on the bottom of the page.
                            /unsubscribe
                            • Synthohol
                              • 5822
                              all fierys should be setup LPR for the best results.
                              just use the correct driver and set this as the port and you can use Direct instead of Print for this.
