Using Memory RX Setting on BizHub C253 while being able to forward faxes
  • eljainc
    • Apr 2014
    • 6
    Hello,
    I discovered earlier today that I can hold faxes in a system user box. Later, I can print selected ones by punching in the password assigned by the Memory RX function.
    This is great, however it states in the C353/C253/C203 Network, Scan, Fax manual on page 9-26 that after enabling the Memory RX function, the Forward TX Setting, TSI User
    Box Setting and PC-Fax RX settings cannot be specified. Furthermore, while Memory RX is on, the forwarding of faxes to an SMB address (i.e. \\WORKSTATION1\C\FAXES) does
    not work.
    Is there a way to hold off printing faxes while being able to forward the Faxes to an external address/computer?
    Mike
  • Synthohol
    Certified Konica Expert
    • 5842
    Re: Using Memory RX Setting on BizHub C253 while being able to forward faxes
    Originally posted by eljainc
    Hello,
    not work.
    Mike
    thats the first thing to diagnose if you want this to work the way you want. add the user name to the permissions of the shared folder, if its a domain PC you may need to type domainame\username.
    make sure to allow full control to the folder with the name you use both on PC and Pagescope. also anti-virus/firewall apps need to be checked if they are stopping the file. this is quite common.
    • eljainc
      • Apr 2014
      • 6
      I think you might have misunderstood my post. I am able to forward faxes to another destination. However, I cannot suppress faxes by only storing them (without printing) and also using the Memory RX setting. The manual states this.
      I did not intend for a discussion on the proper set up of the forwarding. I want to have the forwarding working, but no printing of faxes at the same time.
      • rrrohan
        • Sep 2011
        • 1977
        It's one or the other. I've never heard of anyone needing both
        Sent from my SM-G900I using Tapatalk
        • Synthohol
          • 5842
          there is an option for forwarding without printing if thats what you mean.
          it will only print if the forwarding fails, like if the computer is off.
          if this is not what you are looking for i apologize.
          Forward TX Setting
          Device is mounted.
          [Service Mode] [Billing Setting] [Management Function Choice]
          (5) Incomplete TX Hold
          [Service Mode] [FAX] [System] [Display Setting] [Re-Transimission]
          mounted.
          (6) PC-Fax RX Setting
          1
          Forward & Print : Forward the received text, and print all out
          Forward & Print (If TX Fails) : Forward the received text, and prints out only when
          fails to be forwarded
          Setting/
          Procedure
          • eljainc
            • Apr 2014
            • 6
            Oh, thank you very much. I think this is what I need. I didn't realize that this option would hold off printing unless there was a problem
            forwarding. I will try it when I get into the office.
            Mike
            Forward TX Setting
            Device is mounted.
            mounted.
            1
            Setting/
            Procedure
            • eljainc
              • Apr 2014
              • 6
              Synthohol
              Synthohol,
              Thanks again for your help. The Forward & Print (if TX fails) did the trick. This is going to end up saving us heaps of paper.
              Mike
              Mike
              • Synthohol
                • 5842
                Anytime, glad I could help.
