Bizhub Pro 1051 web roller
  • Kidaver
    Ghoulscout
    • Apr 2011
    • 912
    The web roller for the fusing unit seems to not be advancing. I get build up and it has scarred one upper fuser roller within a month. I've replaced the web roller motor and ran it in I/O mode and watched it turn so I know that is working. I've changed dipsw for it to run more often as well. Even reset counter for web roller. Any ideas?
    "In a cruel and evil world, being cynical can allow you to get some entertainment out of it."
    • 23010
    Re: Bizhub Pro 1051 web roller
    Since you replaced the web advance motor, has it turned at all during copy cycles? As much as I hate replacing boards, you're headed that way. =^..^=
    • Kidaver
      Ghoulscout
      • Apr 2011
      • 912
      Well I guess next time I am at the account I'll get on the phone with tech support to tell me to start swapping boards so I have a request number to send them back when they don't fix the problem lol
      • allan
        RTFM!!
        • 5462
        I had a bad web motor before and it gives a code if the motor itself goes bad. Does the gears look ok?
        Whatever
        • Kidaver
          Ghoulscout
          • Apr 2011
          • 912
          Yeah the gear looks fine and I ran the motor in I/O mode and watched it turn with the web roller cover off. But when I go to the machine after a week or so you can tell theweb roller isn't advancing and it's building up all that toner it's cleaning off.
          • korthr5
            • Feb 2016
            • 39
            Hello
            I have the same problem.... A i solved reseting the counter's of web. (2 or 3 counter related with web)
