Orignal
  • antone
    • Oct 2014
    • 344
    Orignal
    When a copy is made off the glass,tried everything settings! Call Hot line Konica Minolta....copy maded copier ask for next original, I have to hit finish and start.Did firmware also.The settings are done right
    Sent from my SM-N920V using Tapatalk
  • Flash
    • 378
    Re: Orignal
    Make sure machine is not defaulted to 1-2 sided or 2-2 sided.
    • copier tech
      • 8172
      Re: Orignal
      You've not said what model, im guessing a C284 series if so try Bizhub glass copy Utility/user settings/system settings/page 2, there is a new icon for "separate scan from platen"
      • habik
        • 2013
        Re: Orignal
        Yup. Had this as well! Its a bugger if you don't know about it.
        Firmwares HERE
        • SAR
          • Jul 2009
          • 203
          Re: Orignal
          Make sure the finisher is not defaulted to Sort, that will cause that exact issue you have. Touch the Finisher button on the control panel, if sort is highlighted, change it to group, then go to Utility, user settings, copier settings, default copy settings-current setting. Also make sure Auto sort/ group selection is set to yes.
