C5501
  • CrapAimer
    • 296
    C5501
    Hi could anyone let me know how to do banner print on a C5501
    George
  • Synthohol
    Certified Konica Expert
    • 5808
    Re: C5501
    Reference
    Banner printing is not supported on the bizhub PRO C5500/C5501C6500/C6500P/C6501/C6501P/C65hc. This specification cannot be changed. All product change requests for this feature will be denied.
    SPECIAL NOTE: Solution contribution by Clinton Marquardt, ESS
    • dach78
      • Jun 2013
      • 17
      Re: C5501
      Preparation
      ➲ Please use only SMART concept ( bizhub PRO C6500 )
      ➲ Only IC-408 supports banner paper size
      ➲ Please remove any finisher from the configuration
      ➲ Only the bypass is able to handle banner paper
      Engine settings
      ➲ Service mode / System settings / Software DipSW
      ➲ Set Engine DIP-SW 10-0 to 1
      ➲ Set Engine DIP-SW 10-1 to 0
      ➲ Set the right paper size on engine for bypass tray
      Printing
      ➲ Open the document you want to print on banner
      ➲ Select the driver for IC-408
      ➲ Define the right media setting ( Weight, Type )
      ➲ Define the banner paper as Customised paper, e.g. 314 x
      1200mm
      ➲ PRINT
      Restrictions
      ➲ Counter information not clear
      ➲ Paper wrinkle
      ➲ Jam recovery could be difficult
      ➲ No QA test from BT
      ➲ No paper test
