C-4520 on C6500
  • vlad_robas
    • Oct 2006
    • 225
    C-4520 on C6500
    Hi,
    Before this code in the sim test pattern at 90 the coverage was't looking even at all. Consumable's weren't that bad and print was ok.
    It stop's early after the start and show's this code.
    Om the transfer belt are only two stripes, magenta and cyan, the third one, yellow, is still on the drum.
    The belt is spining and i have read about other related post's on this mater. So I have clean the sensors on registration ass'y but that didn't help. Then taped the shutter in the open position.
    I'm asking if it is ok to take the assy out and go to another machine and test it there or if is even related to that assy?
  • laitang
    • Nov 2012
    • 627
    Re: C-4520 on C6500
    Did u perform Color Registration adjustment ?
    • vlad_robas
      • Oct 2006
      • 225
      Re: C-4520 on C6500
      No.
      It simply go in error code after a short period of time.
      Should I try to go in Service Mode early?
      • Synthohol
        Certified Konica Expert
        • 5839
        Re: C-4520 on C6500
        if i remember there is a sw switch to change to disable auto color registration, you reset it to default and then run manual CR.
        • vlad_robas
          • Oct 2006
          • 225
          Re: C-4520 on C6500
          "laitang" advice: Color Registration adjustment, did it
          Thank you!
          Now C-3102 let's read the older post's
