Jamming in Solenoid (SD4) Minolta C6501
  • Andre Luis dos Santos
    • May 2016
    • 23
    [Jamming] Jamming in Solenoid (SD4) Minolta C6501
    Good day Guys, I have a problem with my Minolta 6501, within the technical panel, I tested I / check 80-0 referring to the solenoid (Paper Exit Solenoid (SD4)), this is not said.
    I've done the test of fusion sensors, and are ok.
    But when sends a message front and back, the SD4 solenoid does not operate.
    Has anyone got this problem?
    The following photos in attached
  • Synthohol
    Certified Konica Expert
    • 5807
    Re: Jamming in Solenoid (SD4) Minolta C6501
    What is the jam code?
    Also no photos were successfully attached.
      • May 2016
      • 23
      There is no code, there is a message showing how to make the jam. Just know it's Solenoid (SD4) because he does not reply in I / O mode, and watching the machine work I realized that he does not act. The sheet passes directly by the output of the merger without entering the ADU, thus giving a jam message without code.
        • May 2016
        • 23
        attached images : https://we.tl/lbxjVJ0eYd
        • Synthohol
          • 5807
          please go into service mode under system settings i think and enable software sw 11-7 to 1 for jam code to show on screen when it happens.
            • May 2016
            • 23
            Thank you. I have activated the Dipsw 11-7 , and the copier launched J32-02 error.Any tips ?
            • Synthohol
              • 5807
              After the fusing paper exit sensor
              (PS17) is turned ON, reverse/exit sensor (PS19) is not turned ON within the
              specified time.
              how is your decurler roller?
                • May 2016
                • 23
                specified time.
                [ATTACH=CONFIG]32849[/ATTACH]
                Regarding the I / O check mode does not respond to command 80-00 relating to Solenoid SD4 , is this normal?I will carry out the test sensor PS19 and PS17
                  • May 2016
                  • 23
                  I tested the sensors ( PS17 ) ( PS19 ) the two are working. But I realized that the Solenoid that is in your is not the original , it has a different serial number of this ( 65AAR70400 ) , and I lost the original solenoid years ago , but never ran Duplex. It may be the solenoid ?
                  • Synthohol
                    • 5807
                    you may be able to check it with a meter when you operate the IO mode. if its getting the juice then its the solenoid, if not it may be the ADU board. ive seen both.
                      • May 2016
                      • 23
                      you may be able to check it with a meter when you operate the IO mode. if its getting the juice then its the solenoid, if not it mat be the ADU board. ive seen both.
                      I've been researching and found something related to ICP 8 , I performed the measurement of icp and it consisted fault , I want to change the ICP , but not against it. Can I exchange one of these two with different values ​​?
                      https://we.tl/M3Yvqo8nEv
                      • habik
                        • 2013
                        Measure the impedance of the solenoid. Try for shorts of cables only against the ground (unplugged from board and solenoid). Then measure cables against the ground with solenoid conected only with cables (unplugged from board). If the fuse blew, there is a reason. I think the solednoid is shot, but only you can measure it. Check impedance with similar solenoids in machine. Hope this helps.
                        Off topic: Try lowering your phone or camera resolution (web size settings, perhaps ?)so it can be uploaded within the message. Good luck.
                        Firmwares HERE
                          • May 2016
                          • 23
                          Can someone please tell me what amperage mA Solenoid SD4 of 6501 ?
                          • habik
                            • 2013
                            Hope this helps
                            BTW on the board it says T2000 for that SMD ICP 8 fuse.
                            Check that solenoid FIRST, then fit the fuse.
                            ICP8 DC35VP11CT2000
                            so my guess is(2000mA)
                            24V1 ADU, Paper exit SD
                            ADU pre registration CL
                            ADU middle conveyance CL1,2,3
                            J32-02(duplex only)
                            Firmwares HERE
                              • May 2016
                              • 23
                              Testing the board ICPS , I noticed that everyone was equal to "1" , but ICP 8 referring to the solenoid brand " 142, 143 " in the Multimeter .I believe it is problem in ICP , because I had problems like this and changing the icp worked. But in this case I have no icp 2000mA to change , I have only 2500 mA . Any suggestion?
                              Testing the board ICPS , I noticed that everyone was equal to "1" , but ICP 8 referring to the solenoid is equal to " 142, 143 "I believe it is problem in ICP , because I had problems like this and changing the icp worked. But in this case I have no icp 2000mA to change , I have only 2500 mA . Any suggestion?
