Konica Minolta C280 Printer Driver on MAC
  • mearmi
    • Oct 2010
    • 350
    [Misc] Konica Minolta C280 Printer Driver on MAC
    Konica Minolta C280 Printer Driver on MAC doesn't show duplex/double sided option.
    Please advise.
  • EarthKmTech
    Step aside, noob
    • May 2009
    • 2139
    Re: Konica Minolta C280 Printer Driver on MAC
    keep looking
    it's one of the many finishing options drop down lists.
    (assuming you are using the correct driver)
      • 14813
      You may have to go into CUPS to enable duplexing.
      • Synthohol
        Certified Konica Expert
        • 5848
        Correct, however duplex is the default on pc or mac. Its just trying to be "green"
        Long story short, go to terminal and type cupsctl webinterface=yes hit enter. Close window.
        Open browser and type localhost:631/printers.
        Select the konica and the dropdown that says administration drop down and select default options.
        Under layout you will see 2 sided printing as the default. Change to 1 sided and save. Sometimes thwre is a ok button at the bottom other times you just hit enter.
        Most of the time a password is reqd of the user.
        As far as when sending a print there is a dropdown for layout or finishing that has the simplex/duplex option.
