buzhub c364e temperature control
  • dc-master
    • Jul 2015
    • 39
    dear friends,
    I have a bizhub c364e and I tried to print on some color transfer papers (proworld 301 and 530),
    but while printing the lighter one (301) the paper got stuck to one of the roller which I think was because of too much heat.
    Is there a place in the settings in which I can adjust the temperature of printing?
    thanks in advance
  • allan
    RTFM!!
    • 5462
    Re: buzhub c364e temperature control
    Yes you can in service mode.
    Its under "machine"
    What paper type did you use?
    Whatever
    • dc-master
      • Jul 2015
      • 39
      Its under "machine"
      thanks for your response, I used ProWorld Elite+ Paper (item #530).
      • allan
        RTFM!!
        • 5462
        Hehe. Sorry i mean the paper type setting on the machine?
        Whatever
          • 22999
          Like allan suggests, it would be a lot easier to select a media type with a warmer or cooler fuser temperature, depending on what you want.
          Personally I don't recommend running that sort of stuff through a copier. You may find yourself needing a fuser much sooner than the yield. =^..^=
          • rrrohan
            • Sep 2011
            • 1976
            454 has transparency paper type option. I'd like to assume you already used that option
            Sent from my SM-G900I using Tapatalk
