bizhub c300 color copies are moved
  • javier4065
    • Feb 2007
    • 251
    hello, when I make black copies, they are ok but colors copies are moved . what can I do to solve it.thanks in advance.
  • Synthohol
    Certified Konica Expert
    • 5814
    Re: bizhub c300 color copies are moved
    Hello, try cleaning the 2 sensors under the front of the transfer belt then run colir registration and see if it improves.
    You will have to open the shutter that protects them to get access.
    5 minute job really.
    • javier4065
      • Feb 2007
      • 251
      thanks, I will try it, where is color registration adjustment , in utility or service mode?
      • Synthohol
        • 5814
        service
        • DrMark504
          • 13
          moved how? color reistration shiting each color equally from the black?
          • javier4065
            • Feb 2007
            • 251
            where are the sensors that I should clean?
            I dont see them?
            • javier4065
              • Feb 2007
              • 251
              I send the imagen of my problem. You can see on the pattern that black squares are not the same level that color squares.people say me that it I should change the transfer unit. but I see it good .
              • javier4065
                • Feb 2007
                • 251
                i send the patter the lines are bad. maybe you can help me, thanks.
                • javier4065
                  • Feb 2007
                  • 251
                  thanks for your help. I cleaned ,laser unit, two sensors under the transfer unit end the transfer unit, and the color copies are ok now.
