Firmware for a Bizhub C452
  • Arteminium
    • Apr 2016
    • 8
    Is there anywhere I can find the firmware for a bizhub c452.
    I've already tried Konica CSES, but couldn't spot it.
    Any help would be appreciated.
  • kingarthur
    • 1351
    Re: Firmware for a Bizhub C452
    it's on infohub, search SAL after you've selected the product, when you do install, DON'T install scanner FW, I had one turn into a brick, something to do with the tsunami in Japan & they had to source different chips, so the FW killed the m/c
    • docdot69
      • May 2016
      • 53
      that's right, some of machines, after the tsunami in Japan had scanners from other manufacturer, so be carefull with updating scanner f/w. On the f/w upgrade screen simply deny updating scanner f/w, upgrade all the rest. Same things with bh 223.
      All firmware and documentation on www.infohub.konicaminolta.eu section "archive" if you have permition to that hub ofcourse.
