C224 With evenly spaced cyan/magenta line on color copy only.
  • TheBlueOrleans
    • Aug 2012
    • 232
    #16
    Re: C224 With evenly spaced cyan/magenta line on color copy only.
    Originally posted by Brett GS
    Make sure you do the touch panel adjust,if the machine has latest firmware on it the touch panel adjust wont show so you will have to load earlier version.
    There is an alternative to loading older firmware in order to calibrate the touch panel:
    On the 4e and 8 series machines, press Menu, Counter, Display Keypad, Stop, C, 1 1 6 6, press Start button.
    Wait at least 30 seconds and then cycle power.
    Somewhere there is a tree working hard to produce oxygen for you to live, NOW GO APOLOGIZE TO IT!
