C6000L fuser roller cleaning
  • kandod
    • Mar 2010
    • 58
    When replacing fuser belt, the two rollers inside are covered with some sticky material, it is probably the special KM grease. So the question is should I clean them before putting the new one, and what cleaning material should I use. Thank you!
  • CopierCare
    • Aug 2015
    • 24
    Re: C6000L fuser roller cleaning
    I clean the rolls up each time I replace the fuser belt. I use alcohol. May dry the rolls a little but cuts through the grease and I haven't had one dry out.
    • Synthohol
      Certified Konica Expert
      • 5820
      ive used varn blanket wash for years and never had an issue. with the exception of white cuticles on my fingers, i clean those rollers dry every belt change.
      • kandod
        • Mar 2010
        • 58
        Thank you for the replies, i have replaced the belt and almost immediately the inner edge pressed towards the regulating sleeve
        Any ideas? Thank you?
        • DigiMan
          • Jan 2013
          • 262
          You sure you're using the right belt?
          Is the belt straight side to side?Even the slightest deviation can cause it to flip.
          Also does this thing have a lot number and if so is it placed in the right direction?
          I don't like the new copier I just bought. It says "put face down" but every time I do it, it blinds my eyes.
          • kandod
            • Mar 2010
            • 58
            Found the problem, the fuser roller /2 metal bearing was set up improperly with the limiter from the outside, very stupid mistake, thank you for the help!
