DV510 on C6500
  • adeyemi
    • 378
    DV510 on C6500
    Just a curious one, can DV-510 developer work on C6500?
    Dgtal
  • Synthohol
    Certified Konica Expert
    • 5813
    Re: DV510 on C6500
    knowing the sensitivity of the machine, i would never use any DV other than the correct DV-610.
    even the DV-510 box says "Only for C500" and to top it off the DV-510 is 100G short of the correct amount of DV for proper operation.
    i wouldn't even try.
    • adeyemi
      • 378
      Re: DV510 on C6500
      Okay thanks. What about the other way round...using DV-610 on C500
      Dgtal
      • Synthohol
        • 5813
        Re: DV510 on C6500
        same rule applies.
        consumable formulas are specifically designed for the hardware they run in.
