bizhub C220 fax issues
  • acsolutions
    • Jun 2010
    • 519
    [Misc] bizhub C220 fax issues
    Hello, when I enter a number and I have it off the hook I can hear the dial tone but that's it, constant tone while dialing! There is never a ring and the call fails! I have replaced the fax unit, riser board, and main control board. Fax is set for fax1 in service mode the market area is set to u.s. I went through initialize the fax. I also swapped phone line and machine is currently running on another fax machine! I think I covered almost everything and one of the other techs. Upgraded firmware after it stopped working!
  • Synthohol
    Certified Konica Expert
    • 5847
    Re: bizhub C220 fax issues
    what i've done is unset fax 1, shut off, disconnect the 2 cables from the fax and boot up. shut down and install from scratch by the book.
    you can try a system error clear in initialization in tech rep and see if that helps first.
    good luck or a bad fax.
    just to ask, does it answer a fax?
    • acsolutions
      • Jun 2010
      • 519
      I have tried 3 fax units and two riser boards I have initialized all 3 boards. Good question I didn't see if it received but other tech said no! I pretty much started from scratch every time I changed boards! I was thinking about mv Ram. What do you think?
      • Hansoon
        • Sep 2007
        • 3389
        I had it once. Had to do a machine reset: Service Mode>System1>Initialization. Than do the complete set up procedure first without the fax board installed and than a renew install of the fax board following exact the procedures as in the Install Guide for the MK-720/FK508 Fax Kit.
        Hans
        • EarthKmTech
          Step aside, noob
          • May 2009
          • 2139
          I've had to do an NVRAM initialise to correct a misbehaving fax on this series before, nothing else worked, including full initialization.
          My symptoms were that it failed sending before even attempting or picking up the line.
          • emujo
            • Jun 2009
            • 3009
            Any chance you have the fax admin settings programmed for "pulse" (old rotary phone) instead of tone? Also, I have seen this symptom on an old DSL line without the proper filter installed. Emujo
            • mo0651
              • 1054
              Do you have a test phone to hook up to the telephone port?? If you can dial using that then it seems to be the dialing control on a board. Probably the MFB. Have you changed the mount kit board that the fax board plugs in to??
