Prints-density color problem. C452
  • menosmola
    • Apr 2014
    • 95
    [Misc] Prints-density color problem. C452
    I have a problem with a konica minolta C452.
    As you can see in attached examples, the beginning of prints are lighters.
    I check belt, transfer roller, and laser, but i cant solve the problem.
    Any idea?
  • mo0651
    • 1054
    Re: Prints-density color problem. C452
    Those prints are ran thru in portrait direction? Did you do a stop test?
    • Synthohol
      Certified Konica Expert
      • 5839
      There is an adjustment for 2nd transfer lead edge I believe.
      Play with those numbers and see what changes.
      • menosmola
        • Apr 2014
        • 95
        Yes, portrait direction.
        No i didnt stop test. Best way to do stop test?
        • menosmola
          • Apr 2014
          • 95
          I play but nothing change...
          • tehrancopy.com
            Senior tech
            • May 2016
            • 6
            have you tried cleaning your second transfer roller ?
            • menosmola
              • Apr 2014
              • 95
              Yes, i change for 1 new transfer roller...
              • DigiMan
                • Jan 2013
                • 262
                Strange,had this on a couple of these and what synthohol suggested rectified the problem.
                Did you adjust it correctly?
                Also did you do a panic stop to see if it happens on 1st or 2nd transfer?
                I don't like the new copier I just bought. It says "put face down" but every time I do it, it blinds my eyes.
                • menosmola
                  • Apr 2014
                  • 95
                  Yes, i do panic stop, and image in transfer belt is perfect, i think the problem is on second transfer, but i change second transfer roller and check second transfer mechanism and all seems fine, electrical problem maybe?
                  • Synthohol
                    • 5839
                    sometimes just to see if it is an electrical issue, try setting it to thick 1,2 or 3 to see if the problem changes. if yes then its likely electrical, if no change it might be something mechanical. check the contact point on the copier where the transfer roller gets its juice and the terminal spring that touches it.
                    • imihm
                      • Feb 2014
                      • 77
                      Any idea?
                      Hi there...
                      This is unexpectable problem check the fusing unit...
                      thanks
                      • menosmola
                        • Apr 2014
                        • 95
                        Originally posted by imihm
                        Hi there...
                        thanks
                        problem comes before fuser unit.
                        • imihm
                          • Feb 2014
                          • 77
                          Then make sure the connector to the second transfer roller is not loose...
                          Thanks...
                          • neil greenhough
                            • 51
                            Check the fuser line speed. I have had this problem when engineers have messed with it to stop creasing. Make sure both adjustments are set to default.
                            Sent from my Nexus 5 using Tapatalk
                            • menosmola
                              • Apr 2014
                              • 95
                              Both set to default...
