bizhub C284 Display flickers when moved back and forth
  • Laserbeam
    • Aug 2011
    • 152
    [Electrical] bizhub C284 Display flickers when moved back and forth
  • Synthohol
    Certified Konica Expert
    • 5839
    Re: bizhub C284 Display flickers when moved back and forth
    Konica has a 3 year bumper to bumper warranty, if you clear all the logs and change the install date in service mode the list output will "show" its less than 3 years in the field and the panel can be returned under warranty.
    unless you are not working for an authorized dealer, but thats the downside to being an independent i guess.
    • allan
      RTFM!!
      • 5462
      Hehe
      Whatever
      • habik
        • 2013
        You can't clear some data like detailed code history.
        Firmwares HERE
        • habik
          • 2013
          Try computer/ laptop repair shop or ebay for LVDS 40 pin cable
          Firmwares HERE
          • EarthKmTech
            Step aside, noob
            • May 2009
            • 2139
            It was once available as a replacement part internally, I recall receiving the email. I never had the problem so never had to change it. Its no longer a current machine so i suspect any chance of it being released as a spare part now are long gone.
            • Synthohol
              • 5839
              go old school, use an ohm meter and test all 40 wires from terminal to terminal.
              • habik
                • 2013
                ... Or get a magnyfing glass and solder 1:1 with new wires.
                Sent from my iDon't believe in marketing device using Tapatalk
                Firmwares HERE
                • EarthKmTech
                  Step aside, noob
                  • May 2009
                  • 2139
                  Or,
                  just recover panels from machines returned for recycling.
                  • allan
                    RTFM!!
                    • 5462
                    That is some serious skill.
                    Whatever
