bizhub c300 show error C4765
  • peter anyin
    [Error Code] bizhub c300 show error C4765
    please when i try to print from my bizhub c300, it try to pick paper and then displays C4765, how can it solve this, and i have clean the sd ram
  • Synthohol
    Certified Konica Expert
    • Mar 2016
    • 5840
    Re: bizhub c300 show error C4765
    "> C4765 Extraction hardware timeout • The hardware involved with the extraction function offered by the printer control board (PRCB)
    does not respond.
    could be PRCB or hopefully a loose connector.
    unplug machine and re-seat all the connectors on the PRCB,MFP including ram chip(s) and see if code returns. dont skip any because they are tough to pull out.
    • peter anyin
      thanks alot
      my bizhub c300 does not pick paper it will just be busy as if it is printing after some time it will show miss feed and i have cleaned the paper picker please what do i do thank for the first advice
