jam in fusing unite section -ineo 454-
  • jakani
    • Dec 2014
    • 147
    [Jamming] jam in fusing unite section -ineo 454-
    hello everybody ,
    i get the jam en permanent way , when i remove the paper it all folded , i thought it was the fusing unit so i changed it but still the same problem
    anybody have an idea what might cause this problem ?
    thanks in advance for any suggestions
  • jakani
    • Dec 2014
    • 147
    Re: jam in fusing unite section -ineo 454-
    Originally posted by jakani
    hello everybody ,
    i get somthing like this
    • Synthohol
      Certified Konica Expert
      • 5824
      what is the actual jam code?
      • EarthKmTech
        Step aside, noob
        • May 2009
        • 2139
        check that all the rollers are actually turning and that no belts are misplaced.
        I've had the exit section 1 way clutch fall to pieces before but its pretty obvious when those rollers arent turning.
        • jakani
          • Dec 2014
          • 147
          thank you for replying
          there is no jam code it just show "misfeed detected remove paper as indicated ..."
          i noticed that when i push the "paper exit roller" to the back the paper almost passes the fusing unit , but the end of the paper still stuck in it
          i will check the cluch as you said
          • avecosat
            • Jun 2012
            • 305
            Jam code is in a tech mode , counter , jam counter .
            • jakani
              • Dec 2014
              • 147
              thank you
              • jakani
                • Dec 2014
                • 147
                Jam code is : 30-03
                thank you
                • jakani
                  • Dec 2014
                  • 147
                  hello
                  Update :
                  the problem of this jam caused by CL8 clutch ,
                  i didn't have the same clutch to replace it so i managed to use a CL7 from a bizhub c 253 adding some tweaks to make it work in place of CL8
