Bizhub C368
  • vr4fiji
    • May 2014
    • 8
    Bizhub C368
    I got Bizhub C368 running for 8 months now. While printing the print out is all good but the edge of the print has faded. tried isolated with new dev unit,drum unit still no progress. please do advice if any solution to this.
  • DigiMan
    • Jan 2013
    • 262
    Re: Bizhub C368
    Are you a tech?
    Can you provide some samples?
    I don't like the new copier I just bought. It says "put face down" but every time I do it, it blinds my eyes.
      • 14522
      Re: Bizhub C368
      Have you cleaned the printhead?
      • vr4fiji
        • May 2014
        • 8
        Re: Bizhub C368
        Originally posted by DigiMan
        Are you a tech?
        I am not sure to attached the picture
        • vr4fiji
          • May 2014
          • 8
          Re: Bizhub C368
          Sample attached
          • allan
            RTFM!!
            • 5462
            Re: Bizhub C368
            Print and post half-tones
            Whatever
            • Max
              • Oct 2011
              • 552
              Re: Bizhub C368
              Have you cleaned laser glass?
              • vr4fiji
                • May 2014
                • 8
                Re: Bizhub C368
                No haven't but I took it out seems to be ok
                • vr4fiji
                  • May 2014
                  • 8
                  Re: Bizhub C368
                  I have taken every thing out to clean it and install again. still same problem.
                  faded from the back of the machine
                  • allan
                    RTFM!!
                    • 5462
                    Re: Bizhub C368
                    Stop the machine with the image on the transfer belt.
                    Is the image faded on the belt.
                    Post the half-tones set at 125.
                    Whatever
                    • VChand
                      Re: Bizhub C368
                      Hi, I am from the Fiji Islands,
                      I have been having the same issue, noticed that while printing.
                      Had a BibHub C364, started having the issue after 6 months, techs couldn't fix it, so machine was replaced under warranty. Received a new machine Bizhub C368, now around 8 months its having the same problem.
                      One tech advised to level the machine. we checked and yes the machine was not level, it was leaning to the front, so the prints are faded at the back.
                      see attached image
                      So I have leveled the machine, that is lifted the front, 20 days now, still no difference.
                      Please do note that this issue I had with 3 machines (Kyocera Taskalpha 3051ci, Konica Minolta BizHub c364 and BizHub C368)
                      So I assumed that the placement was an issue... changed placement, leveled the machine, still the same thing.
                      Any help would be really appreciated.
                      Thanks.
