J-3202 on KM C6500
  • Bodi79
    • Jun 2016
    • 4
    [Error Code] J-3202 on KM C6500
  • Bodi79
    • Jun 2016
    • 4
    Re: J-3202 on KM C6500
    Could anybody help me out please, i am in desperate need of support !
    Thanks in advance !
    • Synthohol
      Certified Konica Expert
      • 5853
      take the cover off the fuser, jig the door and see if one or more of the 3 white one way gears are slipping when the fuser tries to go into the pressure mode.
      • Bodi79
        • Jun 2016
        • 4
        • MRK23
          • Jan 2011
          • 19
          Try replacing ps13 on the exit section, I was having the same problem and sensor seemed ok...replaced it and it took care of the jamming issues. Part # is very common to many other models.
          • Bodi79
            • Jun 2016
            • 4
            • jonbonse
              • Jun 2009
              • 737
              Hi
              Did you manage to resolve this error, if so how?
              i have same problem..
              • sadanand
                • 62
                J-3202 or exit sensor jam is due to slipping of one way clutch gears change all 3 gears with one middle shaft hope your problem will be solved
