C-2451 Error on C6000 and a C6500
  • plnewton
    • Jun 2011
    • 49
    Hi All
    This morning to my total dismay both of our machines (a c6000 and a c6500) are coming up with a c2451 error
    I have had this from time to time on the c6500 but only ever once on the c6000 but today for some reason on first start up both machines showed up with the same error and will not start even after many attempts. when this has happened before is usually clean toner densisty sensors run an auto toner density and they have always been fine but not today, they just done want to play ball
    any pointers that you guys might be able to help me with?
    Cheers
    Paul
  • Synthohol
    Certified Konica Expert
    • 5847
    Re: C-2451 Error on C6000 and a C6500
    Are they close to pm cycle or over? Oem supplies?
    • plnewton
      • Jun 2011
      • 49
      I havent checked the exact counts yet but one would only be half way between cycles and the other would be 2/3 the way through a 200k pm cycle
      Both running OEM toners and drums
      is it possible weather could have something to do with it, it was extremely cold yesterday?
      • montadakoms
        the developer of yellow contain low toner density
        you must be change developer yellow or increase toner in developer by forced and then make toner density initialize.
        note that: you can make forced toner by using service mode then state confirmation I/O check then write 54-00 then start until appear number from 135 to 125 then press stop
        • Texers
          • Apr 2012
          • 43
          try go service mode - process adj -drum peculiarity - for 6000 - should be toner density revert - run that routine
          - for 6500 - should be under sensor output check - density return mode
          - max density sensor
          if none work.. try to manually add some toner in the dev mix - unplug TCR - run auto dev charge - then try again the above..(u need to reconnect TCR)
          • tulintron
            • Jul 2014
            • 668
            Good Morning. In some cases, this error is stored in NVRAM, even with the correct values. Where I found I had to install the NVRAM on another device and turn the settings so that it erased the error of memory.
            Already adopted as a procedure when it does not and decides when supplying toner.
            • mircea
              • Feb 2014
              • 70
              Originally posted by plnewton
              Hi All
              Cheers
              Paul
              Well u can check few things:
              Go to i/o check and post the value of toner density sensors.. it should be 125-130 . If the value it's not somewhere near those u can force units to take more toner so the values will be somewhere in that value.
              u should check transfer belt rolles.. one might go lose and when ur printer is trying to adjust it gives one of 2450/2451 codes
              one more thing u can do is to check the sensor from the motor that spins whole belt.. i had this problem myself once.. u just need to pull out image units assembly and look in the back for a motor that should spin the transfer belt unit. It should be in the midle with a black sensor on the lower part.. just try to clean that sersor and see if it clears the error.
              Sry for bad english!
              wish u luck
              • plnewton
                • Jun 2011
                • 49
                This issue is back again, both machines have been fine for the last couple of weeks and today same deal
                Both of them just keep dumping yellow toner, if it errors out and I open it up the drum and transfer belt are just covered with Solid yellow toner
                Previously when I had run IO mode 54-00 and got them down to about 130 they were fine after that but this time no, I can get them down to that and they just error out on startup
                the 6000 wont run a process adjustment either, keeps coming up with error 2
                Any help would be appreciated, If I need to order in a new Yellow dev unit for then that is fine but I dont want to do it for the sake of, I look after the machine for a charity group and they dont have a lot funds just throw away
                Cheers
                Paul
                • tulintron
                  • Jul 2014
                  • 668
                  • nin
                    • Feb 2023
                    • 23
                    I reopen this old post with a question, is there a way to reset the ram without having another machine in the same series?
