Pagescope Data Administrator
  • Arteminium
    • Apr 2016
    • 8
    I'm trying to import the details of a machine using Pagescope Data Administrator, to a local file, to use as a base.
    It can read the Administration, Authentication, and Address settings.
    Yet, under the 'File' tab, the options to import/export are grayed out.
    The machine I'm importing from is a C368, although I also have a C220 on site.
    Any idea what could be causing this?
    Thanks to anyone who can help
  • avecosat
    • Jun 2012
    • 304
    Re: Pagescope Data Administrator
    Sometimes needs to upgrade the firmware or try with a diferent version of data administrator .
    • peter42
      • Jan 2012
      • 110
      For every new bizhub series i reinstall PSDA
      from the newest driver-dvd that comes with the machine.
      Then i can be shure to have all correct interfaces/drivers in the database of PSDA.
      If you use an 2 years old PSDA, you can read actuall bizhub series data but the software has no information how to handle it.
      • jr84
        • Aug 2010
        • 17
        I don't think the current Data Administrator works with the new C368 series
        • peter42
          • Jan 2012
          • 110
          nope, the actual PSDA from their new DVD runs fine and let adressbook be copied from older to new mashine without having stress.
          • B0265
            • Jan 2007
            • 718
            Have you selected what to export (Address Book data or Authentication data)?
            • emujo
              • Jun 2009
              • 3009
              Before you can use the import/export functions you must have an active MFP in your registered list and have pulled down the current address book. Ver4.1.33 works with the C368 (there is a newer function version for this model, 2.1 and of course you must update PSDA to work with this version). I did test this with the "Local File" and it works as expected. Emujo
              • wseyller
                • Sep 2012
                • 1129
                Was gonna say the same thing. It is grey out until you select the item in the list you want to export.
                Sent from my Nexus 6P using Tapatalk
