Konica 7030 Print Problems
  • pepper38_cnd
    Field Service Manager
    • Aug 2005
    • 1075
    #16
    I'm not sure what exactly it is you are trying to accomplish. If I understand your IP and NIC are now functioning. If you are in a server environment, simply set the printer up on the server as a local printer standard TC/IP port and share it out. It will then be in the directory at that point. If you are in a P2P environment then load it as a local printer on each work station via a standard TC/IP port. Again be certain the IP firmware is at level 3 or higher anything below that will not print properly from anything but Windows 95/98.
    Online Store is closed. Chip resetting is a thing of the past! Thank you to all my past customers.
    Now into Ip TV KODI Boxes
    • Albonline
      • Sep 2008
      • 1151
      #17
      when installing as a network printer . you must change the port from 9100 to 10000.
      • pepper38_cnd
        • Aug 2005
        • 1075
        #18
        I think you will find it works better with the port set to LPR and the Que name Prn1.
        • skeptik
          #19
          These people updated from Server 2000 to Server 2003 on their Domain Controller / Exchange server without updating the printer group policy's.
          I think this is the root of the problems, all assitance given is much appreciated. And all was useful.
          If it appears there is more to this I will post again.
