Bizhub 501 SMB scanning
  • Gabriel
    • Jun 2006
    • 139
    How ca I setup scanning on Bizhub 501 to different operation systems?
    My Customer have
    3 windows 7 (1 32-bits and 2 64-bits)
    2 windows 8.0 (64-bits)
    1 windows 8.1 (64-bits)
    3 windows 10 (64-bits)
    Not sure if Bizhub 501 works with SMB version 2 and 3
    Thank you!!!
  • allan
    RTFM!!
    • 5462
    Re: Bizhub 501 SMB scanning
    Use the Konica Minolta FTP utility.
    Change all the IP addresses for the computers to static.
    I don't know if the B501 will work with LLMNR.
    Or use Filezilla server if there is something like a server and use file sharing to the computers from there.
    The new machines does host SMB(SAMBA) server where you can scan to box and share from the machine!!
    Whatever
    • Gabriel
      • Jun 2006
      • 139
      Thank you for your response
      I don't have access to the setup process the Customer's IT team is doing that and they said IIS or FTP is to much work, they want something like plug and play.
      Here is what they want:
      Finisher
      Scanning (SMB)
      Fax
      50 cpm
      I'm thinking on Ricoh MP-5001 (Nothing wrong with Ricoh, I just like Konica Minolta)
      • qbert69
        • Mar 2013
        • 1152
        Finisher
        Scanning (SMB)
        Fax
        50 cpm
        LOL!....if they want "PnP" (Plug 'n' Play) they better get a Kyocera TaskAlfa Machine and implement HyPas PinPoint Scan!!!
        DOH!
        PS--been down this "stupid" road too many times!...easiest thing to do is set-up a Windows 7 64 bit Professional box, set-up scan to folder (SMB) for each person on that machine and then map those folders to each person's computer!...easier setup and management! Alternatively, you can get a PC that has a Core 2 Duo CPU, install Ubuntu Linux and use Samba:
        which is open source. Samba is the open source implementation of SMB which Microsoft implemented:
        REACH FOR THE STARS!!!
        Konica Minolta Planetariums!
