BIZ hub Press 1250
  • IMOT2000
    [Misc] BIZ hub Press 1250
    Hi there,
    I have a Problem with a Press 1250 from KM. I`ve changed Drum, Developer and the Corona Wires, but i also have a low density
    the resolution of the paper type is normal and the IDC Sensor is clean.
    any ideas???
    • 23008
    Re: BIZ hub Press 1250
    How many copies?
    Did you do any of the drum peculiarity adjustments?
    • allan
      RTFM!!
      • 5462
      Past 6Mil the transfer belt contacts gets worn out. Yield is 4 Mil on those.
      Then there is the toner agitator plates they last 4 Mil the yield there is 2.
      Whatever
      • kenpio
        • Dec 2015
        • 201
        had a BH951 doing the same thing, had less than 1 mil on it. I changed the high voltage sensor for the drum. Have not heard from the customer about that problem. Hope this helps.
        KEN
        • allan
          RTFM!!
          • 5462
          KEN
          That sensor should not get any kind of attention no air no vacuum and no cleaning.
          Whatever
