P-14 error in konica minolta bizhub c451
  • janinaresh
    • Jan 2013
    • 18
    In my machine P-14 error appear, I change Black IU but error appear and not proper color registration. So please provide any solution seniors, thanks in advance
  • copier tech
    • 8182
    Re: P-14 error in konica minolta bizhub c451
    Looking at your post I can see the image is being repeated, looks like an ITB problem.
    Take out the ITB, clean the IDC sensors & the ITB, if the problem remains replace the ITB unit.
    • andyf424
      • Jun 2013
      • 126
      what he said.
      • Millennium
        • 30
        Out of curiosity - you stated that you replaced the black IU, so I'm guessing you ran the calibration after, right? Just throwing that out there because I've seen that fix registration issues like this before as well.
        If you have the poster above is correct - ITB.
        • janinaresh
          • Jan 2013
          • 18
          Sir,
          When I try to gradation then Red Light flashing not blue light, so I am not able to machine gradation, and also registration issues.
          • tehrancopy.com
            Senior tech
            • May 2016
            • 6
            Try checking your Magenta IU . Blade or drum problem probably .
            تهران کپی
            • asrar
              • Jun 2012
              • 8
              Originally posted by janinaresh
              [ATTACH=CONFIG]33287[/ATTACH]
              Replace the PH Unit it might help you.
              • sidney
                • Apr 2016
                • 4
                This is a flat cable in the PH unit dirty, sorry for bad English...
                Enviado de meu SM-G531H usando Tapatalk
                • sidney
                  • Apr 2016
                  • 4
                  "Flat cable on the PH relay board"
