Minolta EP 1083
olsen
Agreed, stop the copy before it gets to the fusing unit. If the lines are there the problem is with the drum unit or with optics. If the lines are not there stop the copy part way through the fuser so you can compare pre and post fuser conditions side by side. You might want to start by cleaning the optics, coronas, grid and housings before swapping out parts.the savin2535 is displaying well bet the hiter lamp is not shining and the lamp had been tested o.k.please kindly help.Samir: No, not again. I... why does it say paper jam when there is no paper jam? I swear to God, one of these days, I just kick this piece of shit out the window.
Michael Bolton: You and me both, man. That thing is lucky I'm not armed.Comment
olsen
Hi Gergô and cobiray and thank you so much for your reply. I have cleaned most of the housing and the corona looks like the copy - full of toner and lines. I cleaned it, and put the section in again. Better result, but still a gray copy with lines!! I have cleaned the corona three times -it still becomes durty - mostly on the underneath of the roller.
Sounds mysterious?Comment
