bizhub 423 doc feed 621 not feeding certain times
  • brent
    • Nov 2008
    • 1212
    this is wild.. customer stated the doc feeder will work only during scanning and not copying. I'm like what?
    but as soon as I tried it.. customer was right so there must be a problem with timing or the gear that
    drives the paper feed actuator because during a scan mode they scan twice as fast and the assembly drops down quicker
    during a copy mode using the doc feeder it will not drop down thus not working
    any thoughts on this? am I over thinking it? help
    lol thanks guys
    brent
  • allan
    RTFM!!
    • 5462
    Re: bizhub 423 doc feed 621 not feeding certain times
    Check if the scanning does the same with the resolution set differently. Test 200X200 300X300 and 400X400.
    Whatever
    • Synthohol
      Certified Konica Expert
      • 5814
      Ive seen that, try soaking the spring clutch gear in alcohol for a couple minutes and reinstall.
      If it wont engage immediately and drop the take up it works just like you see.
      • brent
        • Nov 2008
        • 1212
        ok it was the spring clutch. I should have tried that first. Lol
        but I usually overthink these things. The scanner feeds faster do that is why it worked
        • MVPunisher
          • 209
          Not only can it be the spring clutch, but there are 2 white clutches on that same shaft. I usually replace all 3 as a set and it never comes back.
