Bizhub 600
  • ivan
    • Feb 2015
    • 12
    [Error Code] Bizhub 600
    How can I solve error code 6708,I have changed the control board but error still comes up after machine start up in also ruling out the lamp. Please help.
    • 14725
    Re: Bizhub 600
    This is the only bulletin I could find.
    Root Cause
    C-6708 code.
    Workaround/Fix
    PROBABLE CAUSES:
    1. Failed lamp inverter board (Lamp Starter).
    Note: May also see intermittent black copies.
    Replace the lamp inverter board (p/n 57AA 8351 0).
    2. Loose or failed exposure lamp (L1).
    Reseat the L1 connector. If the problem persists, replace L1 (p/n 57AA 8301 0).
    Note: This may only occur in the morning hours.
    3. AGC adjustment level abnormality.
    Flash machine firmware to current level and retest. The latest version firmware or system software is available via the Konica Minolta Download Selector. Access the Selector from SSD Web Support (CS Expert Support) by clicking on 'Download MSDS, Drivers, Firmware and more'.
    4. Firmware update required if the error is generated when ADF key is pressed in the Service Mode.
    Please update the machine firmware to latest version.
    5. Failed CCD Unit and AD Wiring.
    Replace CCD Unit (p/n 57AA -630 3F), and AD wiring (p/n 56QA 9046 2).
    • ivan
      • Feb 2015
      • 12
      Re: Bizhub 600
      Thank you,will have a look at the machine again tomorrow.
      • Synthohol
        Certified Konica Expert
        • 5824
        Re: Bizhub 600
        did you do a trouble reset?
        you didnt specify thats why i ask
        • ivan
          • Feb 2015
          • 12
          Re: Bizhub 600
          Yes I did
