Bizhub C3110 CE pasword reset
  • bgbas
    • Feb 2007
    • 60
    I have been trying to enter admin and CE mode on Konicaminolta C3110. Keep getting authentication error. Anyone know how to reset CE password on this model?
  • BR549
    • 111
    Re: Bizhub C3110 CE pasword reset
    You probably don't need to reset it. Default ce pw is 92729272. You have to press the asterisk key to switch from letters to numbers.
    • EarthKmTech
      Step aside, noob
      • May 2009
      • 2139
      you get 3 attempts before your locked out - it will then even reject the correct password.
      restart the machine at the main power switch to reset the lock out.
        • 23009
        I'll confirm this one. If you do not press the asterisk before punching in your CE password, you are entering alpha characters. Watch the screen while you are entering characters. For about a second you can see on the screen the character you entered before it is displayed as an asterisk.
        I spent a full hour on this particular stupidity. =^..^=
        • Northwestservice
          • Jan 2011
          • 140
          thanks blackcat I spent 10 mins. finding this post
          • ionutkok
            • Nov 2012
            • 24
            Hy,
            Does anyone know how to reset the CE password ? I have a printer where the password is changed. 92729272 not working !!!!
            Thank's
            • srvctec
              Former KM Senior Tech
              • Oct 2009
              • 827
              Originally posted by ionutkok
              Hy,
              Thank's
              Are you entering it in correctly by pressing the asterisk first to get into number mode instead of letters?
              Started in the copier service business in the fall of 1988 and worked at the same company for 33.5 years, becoming the senior tech in 2004 but left to pursue another career on 4/29/22.
              • ionutkok
                • Nov 2012
                • 24
                Yes, I'm a service technician. I have the same problem with bizhub 4050 ... I did not find a nvram reset tools like bizhub c220, c224, 223 etc . May be someone has a solution .
                Thank's
                I.M.
                • byronf
                  Senior Member
                  • Sep 2017
                  • 109
                  Thank's
                  I.M.
                  1. Touch Menu.
                  2. Touch [Counter].
                  3. Touch [Keypad].
                  4. Press the following keys in this order.
                  Stop -> 0 -> 9 -> 3 -> 1 -> 7
                  (With this procedure, activate the access lock release timer to start timing.)
                  5. When five minutes has elapsed after activating the access lock release timer, the access lock will be released.
                  • ionutkok
                    • Nov 2012
                    • 24
                    Originally posted by byronf
                    1. Touch Menu.
                    2. Touch [Counter].
                    3. Touch [Keypad].
                    This is a solution if you entered a wrong admin password for 3 times. Not for CE Password reset !
                    Thank's
                    I.M.
                    • tsbservice
                      Field tech
                      • 8020
                      This is solution when you're locked out of CE mode.
                      • ionutkok
                        • Nov 2012
                        • 24
                        Ok Loked .... My problem is CE Password reset !!! Do you have a solution ? Stop -> 0 -> 9 -> 3 -> 1 -> 7 not working !!!
                        • tsbservice
                          Field tech
                          • 8020
                          You better start your own new thread with your woes.
