Are the received faxes also reduced to 64%? =^..^=
Digging up an old thread, but these issues never fully die. Apparently. Same issue on a C558. Outbound faxes rotate 90 degrees. KM had said similar things when I opened a ticket a few months ago. Update firmware. Try a new fax board.
Two fax lines, though. Trying to isolate which board was having the issue, I had initially set Line 1 to Tx/Rx, and Line 2 to Rx Only. Issue recurred. Okay, swapped the boards around, same setup. Original Line 2 became Line 1, Tx/Rx, and the other board was Rx Only. Seemed to work fine for a couple of months until I said something about it to one of the onsite IT guys. Jinxed it, perhaps. Got a call back, it happened again.
I'm about to call SSD back to see if they have any other recommendations, but I figured I'd check here first. Did y'all ever figure out a solution?
I had a similar issue with a C558 but with scans being rotated. I didn't end up making a ticket because I didn't believe the customer at first. After testing sure enough it would happen. I performed the adjustments for the ADF like you're setting up for first time , and I updated the fw to the latest available and after multiple tests the problem seemed to be resolved. A month goes by and the customer was complaining about the same issue. After multiple tests I never saw the issue happen but the customer kept claiming it would happen. I replaced ps10 (A5C1M50100), ps11 (A108M50000), vr1 (A1UDM50100) , after looking at a few copytechnet forum posts and glancing at the theory. They have not called since but my next thing to try is the adf board and checking with KMBS for any suggestions. Good luck
