Konica Minolta Bizhub C454 C-9403
  • Alex1
    • Oct 2012
    • 285
    Hi,
    I have a Konica Minolta Bizhub C454 displaying a error C-9403. I have a finisher / hole punch connected, i was reading on the error which shows it can be ADF CIS Cable, i then unplug the finisher the error goes away and the machine works with no error. When i plug up the finisher the error appears. I foynd that very strange any suggestions??
    • 23009
    Re: Konica Minolta Bizhub C454 C-9403
    I find this very strange also. But the code still refers specifically to the CIS white level reference. Order the cable first. I had a case that was much more convoluted than that, but don't worry about that now. Cable first. =^..^=
    • pe6ohh
      • Nov 2009
      • 17
      Hello!
      Can anyone tell me the part-number for that ADF CIS Cable? I mean those which look like USB cable.
      Thanks!!!
      • copyrooks
        • Oct 2013
        • 210
        ADF cable: A3CEN11711
        • PCC.TONER
          • Mar 2017
          • 13
          Originally posted by Alex1
          Hi,
          Correct the harness connection between CIS and DSIPB if faulty. 2 Correct the harness connection between CIS and CISPU if faulty. 3 Replace CIS. 4 CISPU F1, F2 conduction check. 5 Replace CISPU. 6 Replace DSIPB. 7 Replace MFPB.
          Linda
