Bizhub 36 hdd full error
  • Intone
    • Apr 2015
    • 68
    machine is getting an hdd full error, reformatting hdd worked before but will not work anymore. did firmware about six months ago to fix other quirky problems. outside of replacing the hdd, any suggestions? thank you.
  • mo0651
    • 1054
    Re: Bizhub 36 hdd full error
    Is this happening when you are scanning?? What are the settings?
    • Intone
      • Apr 2015
      • 68
      it was happening when they were scanning
      • mo0651
        • 1054
        Check scan settings, are they scanning with "compact PDF"?? Set it to PDF.
        • Intone
          • Apr 2015
          • 68
          I will check that and report back. thank you.
          • Synthohol
            Certified Konica Expert
            • 5809
            Why not try enabling hdd overwrite mode 1.
            It will write 0x00 over the scanned data freeing up the space to be used again.
            It will erase the addressbook initially so back up all the settings first.
            • deleuex
              • Nov 2014
              • 8
              I had the exact same service call I tried formatting the hdd, updating firmware etc and the suggested fix from Konica was exactly that which was switching to PDF (not compact) then setting it as default settings.
              • allan
                RTFM!!
                • 5462
                There is a special firmware fix out there for this same problem.
                Not sure of the ver.
                Whatever
