C287 series common squeak locations
  • EarthKmTech
    Step aside, noob
    • May 2009
    • 2139
    Lets get a list going
    I've only been to 2 so far and both have a mild squeak shortly after paper pickup from any trays but stops before fusing.
    No one is complaining yet but it will come!
    I couldn't find the cause though didn't have much time to investigate fully.
  • tech51
    • 846
    Re: C287 series common squeak locations
    I've only been to one since my training and that was for squeaking!
    It was the idler rollers that sit on top of the fuser in that case, but while I was there I greased/lubed as many of those plastic idler rollers with metal shafts as I could find.
    • allan
      RTFM!!
      • 5462
      I have had 2 brand new machines with clicking noises.
      No time to look at that yet.
      If it does that from the start at least the customer thinks its normal.
      Whatever
      • docdot69
        • May 2016
        • 53
        the same problem on mono machines 227? if that, so i say it is normal and it slowly quiets as you print copies, and finaly stops.
        i had 3-4 machines brand new, and when i printed List Otput it was clicking from the start, but after about 50-60 print it stops. The noise was volume down as the copies prints. so maybe color series have the same issue. gotta check on my brand new c227.
        • habik
          • 2013
          Firmwares HERE
          • EarthKmTech
            Step aside, noob
            • May 2009
            • 2139
            there is now special firmware for reducing duplex noise (slows down PPM speed in duplex, customer needs to accept this before installation) Available on request only, don't think they will release it for everyone
            I hear today they released a firmware for reduced fusing noise too ? Not sure what thats about.
            • vedder
              • 131
              Hi everyone, we are having some squeaking issues on a c227 and a c287, we have fit a new fuser to the c287 along with new bushings, nylon rollers etc in the fuser exit ( that is where we are sure the noise is coming from, somewhere up there anyway) which cured the fault for a couple of days, then returned. The noise doesnt happen with the door open and interlock cheated, so we stripped and lubed the top section on the door and the section on the fuser with the plastic rollers on (the bit which doesn`t come with the fuser) and again, the problem was cured.... until today, this one is driving us mad, and it doesn`t help that one of the machines is an hour and half away from the office.
              Any advice would be appreciated on this.
              cheers
              • EarthKmTech
                Step aside, noob
                • May 2009
                • 2139
                i have not changed a fuser in one of these yet.
                but the black plastic part cliped onto the fuser with the gray rubber rollers on a single shaft IS NOT lubricated from the factory. The centre sadle part and even the actuator rubs on the shaft as it turns and causes high pitched squeaks. Does this come with the fuser or not ?
                • vedder
                  • 131
                  no that doesn`t come with the fuser, thats the part we went back to, removed, cracked open and lubed up, you can clearly see where its been rubbing on the actuator arm and what not, so all lubed up, machine was running fine, a squeak when we started, no squeak when we left, happy, but unfortunatley, 4 days later it is back.
                  • EarthKmTech
                    Step aside, noob
                    • May 2009
                    • 2139
                    what grease did you use, it has to be high temp grease anything else wont stick around long.
                    I use high temp teflon grease has not returned for me yet.
                    Nothing worse than a dry shaft;
                    • vedder
                      • 131
                      yep, thats the bit we were working on, its high temperature grease from katun, normally does the trick so hopefully thats not the issue, I should add as well these machines are nearly new, less than 20k on them, how many has yours done? we have a lot of c227`s out and so far not had many issues (apart from these 2) It`s only one of the two that has come back in (so far) so maybe one hasn`t got as much grease on as the other (clutching at straws,lol)
                      • EarthKmTech
                        Step aside, noob
                        • May 2009
                        • 2139
                        this one had about 40k on it and it was in a dusty warehouse back office.
                        I remember it clearly because I noticed their IT loaded an incorrect driver on the server and every single one of those prints was registering as colour, even though 99,9% of what they were printing was black and white. LOL. That first bill was gonna cause some outrage.
                        • vedder
                          • 131
                          lol, if it`s anything like our place, we would get the blame for that despite the fact we didn`t put the driver on, you`ve got to love customers.
                          I take it since you lubed that section up it`s been ok?
                          • EarthKmTech
                            Step aside, noob
                            • May 2009
                            • 2139
                            That was 2 month ago, it was driving the girl sitting next to it bonkers so if it made the noise again she would of called again. Though you never really know with this industry maybe she just doesnt want another visit from the morbidly obese earthKMtech. Either way works well for me
                            • EarthKmTech
                              Step aside, noob
                              • May 2009
                              • 2139
                              FYI, this is what I use now.
